Hi All - Back again
Follwing last weeks impressive fix of replacing my low speed fan resistor to cure the RCD tripping fault, this week I are be mostly scratching my head again.
To my surprise, 3 days after fitting the new resistor, the RCD tripped again. When I switched it back on, it occurred to me that the fan wasnt actually running - I figured this after realising the casing was getting pretty hot to touch.
Much deliberating later I found the microswitch on the manifold to not be switching - it would do manually (if I pushed the little lever on the microswitch the fan runs normally), but the pin going to the diagraghm on the manifold was pretty stiff.
I duly ordered a replacement diagraghm and for good measure a new microswitch, replaced this (after cleaning it all up) and then tried it again.
Bingo - everything is working o.k - no tripping of the RCD, and I can switch the heating on no problem....except, the burners dont fire up when I switch on the hot tap.
As a result, I can only get hot water when the CH is running.
If I look at the pins on the diverter valve and manifold, whilst the better half turns the tap on, they seem to go in and out in sync, which would make me think this was o.k.
The only other slight concern I have is that resistor gets damn hot almost as soon as I switch the boiler on - I cant ever recall if that was normal. I have got the old resistor, whcih I plugged back in, and it acts in the same way.
Any ideas where to turn?
Cheers
Neil.
Cheers
Neil.
