hi can anyone help here PLEASE i have a vokera 20-80rs flowmatic combi boiler and until now has worked perfectly, the problem i have is this, when boiler comes on and rooms get to temp it shuts down as its meant to do but wont fire up again , the pilot light is on and you can here a fan or pump running but the burner has not lit up even turning hot water tap on does not fire it up but if i leave it off for 10 mins or so and it cools down switch it back on it works fine until rooms are at temp again and boiler shuts down any help would great . ps a new thermo coupling was put on a couple of years ago because of similar problem so i have tried putting a new one on again but no luck this time
