I put this wall up a couple of years ago. Comprises 'Mayfair Yellow' handmade bricks topped by engineering bricks. Mortar mix was 4:1 soft sand to cement.
Bricks, sand and cement were purchased 'new' from a local Builders Merchants. Cement was Bluecircle Mastercrete (yellow/blue plastic bag version), and was well in date.
The mortar between the handmade bricks has completely failed and is crumbling out like sand. The same mix between the engineering bricks is perfect - only crackinig because the supporting bricks are not stable.
When I put the wall up I was aware that the handmade bricks were drawing the moisture away from the mortar, so I soaked them before laying; doing this the mortar appeared to set at the normal speed and appeared to fully harden over the course of several days
What have I done wrong?
Cheers
Cheers
