So for context, conservstory being built on 52cm dwarf wall using concrete blocks laid flat.
So building the wall and measured exactly where I need the gap for the French door to fit in. Problem is the blocks end short of this by 6.5cm.
So too small really to be chopping blocks, especially with them being 140mm thick not so easy to do that accurately.
I'm thinking I have two solutions but appreciate your thoughts...
1) mortar gap exceptionally wider, so between the 2 blocks that would mean mortar thickness of 4.25cm which does not seem right...
2) place a mortar gap of 1.7cm and use some 4x2 timber so close the gap. Screw that to the blocks then faster the door to the wood, or even I suppose some 150mm concrete screws and straight through the frame, wood and in to the concrete.
Thoughts please? Would there be any issued with 2).
I did think possible chop 2x blocks in to 30cm and do that but splitting these 140mm thick blocks doesn't split that accurately or straight inside.
