MOT Help
27 Nov 2013
Yorkshire
hi,
Might sound like a daft question . . .
My car currently doesn't have a spare (it was knackered so i chucked it)
My mot is due next month. is it compulsory to have a spare tyre?
I have space in the boot where my old one was.
Not that I know of.
But what do you do if you get a puncture? Why chuck the old one? Would have been better to stick a new tyre on it surely?
hi,
basically i bought the car last yr and the guy didnt know it had a spare i didnt until about 8 months later when i got slow puncture.
I'm going to get a new one just moneys tight so just needed to know if once was needed for the mot (feb is a crap month mot and tax both due!)
Your local breaker should have a wheel for you, whether normal size or the narrow space saver type.
Good luck with the dreaded MOT
As Burnerman says, a spare wheel & tyre is not needed & if present would not be inspected as part of the MOT.
If you're interested, the link below points to a guide published by VOSA about the MOT test including a list of the vehicle parts which will be tested:
[Your car and the MOT]
Your local car breakers is likely the best bet - that or ebay.
I'd get a full size wheel or just a space saver if your stuck for space.
The spare is not required under the MOT, but do not put a defective wheel/tyre in as a spare, as that IS inspected because it shows your intention and ability to replace a road-wheel.
A tester may look at the spare and if it is defective could well give you a bit of, probably deserved, verbal advise that the spare isn't legeal and might be worth your replacing it but as said not part of the MOT..
The MoT manual said:
This inspection applies to tyres fitted to the road
wheels only. The vehicle presenter should be
informed when it is noticed that there is a defective
tyre on a spare wheel.
has this changed then?
i was always lead to believe that if a spare was insitu then it had to comply.
Yes I seem to recall that too. I'm not sure of the change date, but that was from the latest manual from VOSA's website.
