mould
2 Oct 2016
Essex
Can anyone point me to the most effective method of removing black mould from silicone beading (ie showers cabinets, window frames etc) without effecting the sealant ?
Thanks in advance folks.
Neat Domestos and a toothbrush - leaving it for around 20 minutes or so may have some effect. In a shower situation its best if the silicone is dried after each use.
John :)
Try rolling up toilet roll in long strips and soak in bleach, leave for an hour or so then remove, worked a treat in my shower.
I also now use an old spray bottle filled with diluted bleach and spray shower after i use, no sign of mould.
Jim
Mould indicates lack of adequate ventilation , leaving bottle of shampoo etc on the seal exacerbates it .
I heard that weeing in the shower encourages it.
I would recommend getting Astonish mould and mildew remover spray, it worked brilliant for me, only cost about £1.00 and you can get it from Home Bargains, The Range also sell it. I sprayed the areas daily over a couple of days and it went completely. Have used expensive stuff in the past which didn't work.
I used this method last year and it didn't work well. The mould went from black to brown. I bought Cillit Bang's version of the mould remover and it worked about 90%. Still have some stubborn areas but I'll leave this now until I remove and reapply the silicone.
Much the same result I've just achieved with a 50/50 bleach & water mix. I'm of the same mind as you regarding future options.
Thank you for your reply.
