We have a small (40cm x 40cm) solid oak (so quite heavy, one person can hold in position, but not for long) bathroom cabinet that is resisting attempts to get it on our wall.
I marked out 4 holes in a 30cm square and proceeded to try to fit some self-tapping plastic cavity wall fittings. My plan was to do that, then mark exactly where the centres really were on a paper template and then drill holes in the rear of the cabinet so I could screw it up.
Problem is, it turns out there isn't enough of a 'cavity' before hitting the masonry wall behind I tried cutting the plastic fittings down a bit, but then the problem is that the screws are too long even allowing for the thickness of the back of the cabinet.
On measuring, it seems I have, at best, 27mm from the front face of the dry wall to the front face of the masonry, so no real surprise that the pointy bit of the fixing was hitting the masonry before fully engaging.
About the only thing I can think of is to try to drill through the dry wall, air gap AND masonry, poke a rawlplug right in on the end of a thin screwdriver and then use the masonry for the fixing rather than the dry-wall.
Is that likely to work? Is there a better way? Or am I going to have to give up fixing anything to this wretched wall.
Help appreciated!
Roger
Help appreciated!
Roger
