I hate plumbing. I just moved a radiator to the other side of our bedroom. I replaced 15mm copper pipe with speedfit and now the radiator is not getting hot? The inlet pipe is really hot but it doesnt seem to be flowing through the radiator as the outlet pipe is cold.
I noticed when i moved the radiator that it appears to be plumbed as a one pipe system as both the inlet and outlet pipes connect to the same main pipe in the hallway. However it worked before so i just left it as it was. Any ideas???? is it cause the speedfit is too narrow at the inserts? or maybe because it is a one piple system and now the water has to flow an extra 2 metres to get to the radiator?
Croz
Croz
