Moving a Window
18 Jan 2009
Derbyshire
We need to move an upstairs window by approx 600mm to make room for a new loft staircase. Currently there is a wooden lintel in place above the window which will need replacing.
The loft extenstion has a large beam directly above the new window position with a loading of 8KN on the wall (although not loaded yet as conversion not complete).
What type of lintel should I consider for this job - concrete, box steel or even a short length of UB? What are the relative strengths of these?
Note: The window is only 820mm wide and the walls are 9" solid (no cavity).
Thanks for any help.
Mark
I'd go for a 9" "catnic" that's a generic term -there's various types to choose from just go to your local merchants & have a word.
i would imagine the SE who specified the 'large beam' will probably help as if it bears above this wndow his calcs will no doubt be affected..
Errmm- missed the point about the "beam" :oops:
It's difficult to envisage the position of the beam & window, also the relationship with the external structure, ie brickwork, rendering etc.
If there is external brickwork showing above, then a catnic type lintol has to be preferred. If however the window is tight to the eaves- and it's hard to imagine that it is- then your beam will do the trick.
Thanks everyone for there input.
We decided to put a new heavy duty steel box lintel above the window just to be on the safe side.
Probably a bit overkill but at last we know it's safe.
Mark
