Hi, finall getting rid of the pricey complex metering. EDF are coming out soon to remove my 24hrs meter and fit an E7. Then sometime after that, remove my second deemed off peak meter that switches on for up to 10 hours a day. Of course I need some sort of timer for when I loose this meter. Each meter feeds a CU (the deemed off peak feeding the heating)
Currently I have two meters doing:
Deemed off peak meter/E10: Feeds Consumer Unit with underfloor heating and Immersion heater
24hrs meter:runs the CU that does everything else
I have fitted timers for the underfloor and immersion heater, I want EDF to fit a E7 meter which will provide 24hrs supply to BOTH Consumer Units. So, at 11.30pm (or whenever) the WHOLE house gets the "cheap" electric. If needed, I can then use the immersion heater on booster during the daytime.
Does this seem ok?
James
Does this seem ok?
James
