Moving masanory hole
19 Sep 2015
I need to make new holes only a few mm next to the current pilot hole, I'm thinking I need to plug/ fill the current hole, can anyone advise me what's the best way to do this? The hole needs to be strolg
Depends on how big the hole is.....if it's pretty small then use a small diameter drill first and then progress to a bigger one.
Are you going to use a core drill or something?
John :)
How big is the pilot hole? you could just hammer in a wood plug which would allow new hole to be drilled or fill the pilot hole and then drill.
I ended up putting car filler in that should do it, thanks for advice chaps
