Moving my BAXI Combi 105e , help.
25 Nov 2007
West Glamorgan
Hope someone can help. Im no expert on boilers. At present my boiler is on a kitchen wall, and is controlled by the flip down panel on the face of it.
I want to move the boiler to an exterior wall, outside property to create more space. Im obviously building a brick insulated outhouse just big enough to protect the boiler and gas meter box.
Is it possible to connect a simple programmer panel, so i can still control the boiler from inside the property. Please explain as much as you can on this and if it is possible, are there any recommendations on our part. thank you.
You could have a wireless programmable room stat fitted.
Your Corgi gas installer and part P qualified electrician should be able to advise on actual site requirements.
Or even a wired one - you will have to make a few holes through the wall anyway :wink:
Don't forget the frost protection!!
