Moving rad valve across joist for new towel rad
11 Sep 2011
Surrey
Swapping existing radiator for traditional type towel radiator and as pipe centres are closer on new rad and I want to keep it central under the window I need to move supply for one valve the other side of a joist below.
Looking at the joist in question there is suitably sized hole already in it right where I need to move the supply. Only issue I see is it's in the last .25 of the joist (almost at eend of joist).
Do I just go the easy route and use existing hole or patch up hole with ply and make new hole in recommended zone? Thinking another hole is a bad idea..
If the hole is already there then I would use it. You would probably weaken the joist even more by trying to patch up the current hole and drilling a new one!
When the architect designed the house I am sure that enough tolerance was given so that slightly weakening 1 joist would not bring the whole house down! I wouldn't let it keep you awake at night :wink:
Cheers TCC. Think I've been a silly boy to think too hard about this. You're common sense makes sense!
:lol:
