Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Cheers Bahco. I was rather hoping for an explanation of how to do it without draining!!!
Unfortunately I do not have a header tank (just a combi downstairs), so I guess the bung (whatever that is) is out of the question?
Thanks.
shut the flow / return.
shut your rad vaves both ends, drain rad and remove.
then when working on pipes put a bowl under one rad valve and open, when a vacuum has been made the water will stop flowing then you can remove the valve and alter the pipe.
only work on one pipe at a time.
