Hi guys
I usually hang around the electrics forum but thought I would ventre over to here.
My mum has just moved into a new built house. She's hot a Y plan heating system with mains pressure quarter and boiler in the garage. The system has been plumbed with what I think is 10mm plastic pipe (that's a guess)
So the 3 questions I've got are
1 on the boiler there's a sticker saying its filled with fernox inhiberter so when I drain the system won't this be lost? If so should once the radiators are moved I refill the system with new fernox? And ifso how ?
2 I know this is a stab in the dark but how do you release the pipes from the radiator valves? I've used the push fit fittings before but the valves don't seam to have a collar on them which you push in to release I haven't looked closely at them yet so they mite be there and I've not seen them
3 I need to extend the plastic pipes to the new locations so just want to ask are all plastic push fit connections the same and can you use any or do you have to use a certain brand/make the same as the pipe ??
Cheers
Gaz the Sparky
Cheers
Gaz the Sparky
