Moving router
13 Jun 2011
Lancashire
Require some advice please.
House is all gutted and understairs i want to make a hub centre point for cctv dvr alarm panel and broadband router.
I am doing the first fix throwing all the cables in.
My question is i want to move the braoadband router from to outer wall to understairs hub what cable do i need to put in??
At the moment there just is a telephone cable coming into the house from the rear outer room
Are on Virgin cable broadband or BT? Do you have any pictures of what the current cabling is?
You may have already thought about this but I would also just consider WiFi signal strength from under the stairs.
Thanx rsgaz
How many cores 6 or 8??
Cn i use ca6 instead??
What if it was virgin im assumin same again cw1308 and rg6 or rg59 or similiar
Then your router would need coax, possibly RG6 or RG59 as you mention. Depending on distance you may need to change the attenuator if there is one.
Now why the move exactly. If you don't have good coverage at the other end of the house, then the easist course is to get a signal repeater, and plug thatsomewhere in the middle of the house. Or you could for an access point, or use a powerline adaptor instead.
The reason for the move i was goimg to hard wire ethernet cable in every room (future proof) fir sky boxes etc etc
If it's a BT line you've got, then have a chat with one of the Open Reach vans, and see if they can help. They have the kit to route the existing incoming point to the new hub centre location, and it'll give you a dedicated broadband connection as well. If you've creating a wiring hub using ethernet cable, then consider putting 2 points in each room to give you flexibility in the future.
I'm not sure how a Virgin installation would be handled in the future, as they bring the conector box in to the room, and then I think you have the phone, the router, and the broadband at one location, so it might mean that you get it installed in the hub location, and then have to route the TV conection to where the TV is.
