    Dismiss Notice
Moving socket up vertically and then (possibly) horizontally
Discussion in 'Electrics Outside of the UK' started by RobieS, 2 Apr 2009.
  1. RobieS
    RobieS
    2 Apr 2009
    2
    Thanks Received:
    Country:
    EDIT: Answer received. Mods - please remove this topic (as I can't delete it)
    I need to move (& possibly add) a socket to a wall. The socket is currently mounted on a skirting board. Now, can just dig up a *vertical* channel above the skirting board and install a new socket there?
    Also, if I want to move that socket *horizontally' say about 2 feet, could I dig a *horizontal* channel just above the skirting board and lay the new wiring upto the location of the new socket?
    Thanks.
    Robie
  2. Sponsored Links
  3. ColJack
    ColJack
    16 Feb 2007
    11,795
    Thanks Received:
    410
    West Midlands
    Country:
    no you haven't received an answer yet, not a complete one anyway..
    you cannot go horizontal above or behind the skirting then vertical to move a socket two feet... this is not a safe zone as there will be no indication of the horizontal cable..
    more specifically you CAN do it, but it MUST be in steel conduit or trunking
    as wingcoax said.. run it under the floorboards to reach the desired position then up the wall..
    alternatively,move the existing socket up to a worakable height, THEN horizontal to the new socket..
    extra sockets are always handy..
  4. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
    Is that a requirement of the NEC?
  5. ColJack
    ColJack
    16 Feb 2007
    11,795
    Thanks Received:
    410
    West Midlands
    Country:
    which part?
    are you allowed to run outside the safe zones if it's rcd protected?
    are you allowed to run outside the safe zones if it's wired in metalic sheathed cable?
    I was trying to make it simplified for the OP rather than just quote the regs book at him verbatim..
  6. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
    I don't know - I'm not familiar with the NEC, so I can't say. That was why I asked if it was a requirement of the NEC.
    I don't know if the NEC defines the concept of "safe zones", or what should be done if cables aren't run in them, so I can't say. That was why I asked if it was a requirement of the NEC.
    But surely you must be basing your advice on what the NEC requires?
  7. ColJack
    ColJack
    16 Feb 2007
    11,795
    Thanks Received:
    410
    West Midlands
    Country:
    I never pay attention to peoples ridiculous locations... many people on here claim to be somewhere they are not.. and change locations every fed weeks or so...
    he posted in the electrics UK so I gave advice based on UK electrics..
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
