Hi chaps,
I need to move rotate the soil stack T piece in the photo below, so that it faces down the wall in the opposite direction (i.e. rotate it 225 degrees)
I don't know much about non push-fit soil fittings from the 1990's, but I'm guessing that that existing T isn't going to want to rotate around? Will the bottom joint have been solvent welded, or is there a chance it's just a push fit in to a plastic rebate?
There's a lot of pipe work at first floor level, so lifting up the pipe work to slot in a new T fitting isn't really an option. Are there any special fittings around that can help in situations where you can't move either end of an existing soil pipe?
Cheers
Gary
Cheers
Gary
