Moving Toilet
3 Sep 2004
Hi All
I want to move my toilet from 1 side of the bath room to the other. How easy is it to re-plumb the waste pipe to the existing SVP. IE can the waste pipe go through ceiling joists ???? What's the minimum fall is required to meet Building Regs ??
Evofluff
imo, no,but the top can go around the ceilng joists (unless thats what you meant)
you may want to consider an "auto air vent thingy" like this
you can tell i am not a plumber cant you ".............thingy"
Hi breezer
I'm not sure if I have explained myself properly. The bathroom is on the first floor and I want to put the new waste pipe in between the ground floor ceiling and the first floor.
Ceiling Joist run from left to right.
Can anyone else help
Fluff
What about toilet in top left corner? Then waste can run above joists (and floor) and can be boxed in. Then either out through wall then right turn to stack or right turn inside (bends aren't very tight though so big box in corner). and run inside to stack.
Option 2 is a macerator. Goes behind toilet and chews it up into small pieces (might be repairable if it breaks but I'd just buy another wouldn't you ? :eek: ). Waste pipe for these is only 20mm.
For both case you would need P trap toilet if you current one isn't (and you want to re-use it).
Hi Malc
Thanks for the reply.
Option 1 is a good idea but I was hoping to stick the 1000 x 800 shower there.
Option 2 is out the question. I can't stand macerators, there so noisy.
Any other ideas ???
Evofluff
At present your toilet is well positioned to meet existing soil pipe.
By moving to the other side you will have to run soil pipe under floorboards to connect on to SP.
As soil waste pipe is 110mm you will not be able to drill thru joists and have correct fall without your floor in danger of collapsing :LOL: so leave be or move soil vent pipe.
What about below? That is go down through the floor then under the joists and out the wall to the stack. Of course you would lose ceiling height in the room below but perhaps that does matter. For example it might be a cupboard. If it is your lounge, well I can't a 4in pipe even if it is box in being acceptable :p
Hi Malc
Good idea Malc. The room below is the Kitchen / Breakfast room, could the pipe work be located into the stone wall ??? The stone wall is about 500mm thick. Very old house.
Evofluff
Even if it could would you want to? Carving a 110mm channel in solid stone would not be my idea of fun.
