Multi testers
17 Jun 2007
Yorkshire
I have a Robin 1620 which I am thinking of updating.
I've looked at Megger 1552 and Fluke 1652.I'm looking at about £500.00 ish
But also now seen the Alphatek range.
Help please
I've an Alphatec / Metrel Easitest. Very easy to use and does most things. Instructions in weirdish. A bit expensive at the time, but I've never regretted getting it. Now 2+ years old, has been soaked, dropped and no problems (recalibration showed no deviation). Leads are a bit short for comfort sometimes. Battery life good.
HTH
Thanks for that ,I've look at Alphatek they look like good value for money.
All I want is RCD auto and Ramp test otherwise just the normal test.
Cheers
I've an Alphatek too and no complaints. (Batteries recharge in the tester so no Duracell munching).
Whatever tester you go for you should keep an eye on what the requirments may be for the upcoming 17th edition of the regs. Touch Voltage is, I believe, to be an additional requirement of the RCD test.
Some testers already do this, some dont, so make sure your new baby is future proof.
Surely you can work out touch voltage multiplying the RCD rating by the Zs of the circuit :?
