Hi All,
We've just had the whole house rewired but have an issue with several of our downstairs lights flashing/flickering intermittently. Video here.
The electrician will be coming back, but he's not local so he won't be here for a couple of weeks, so trying to diagnose (and understand if I should be concerned) in the meantime.
Things I've deduced so far:
Any help appreciated!
Cheers,
James
- It happens rather intermittently, but at least once per day. Sometimes it's just for 10 seconds, other days it's several minutes!
- It only affects the downstairs lighting circuit.
- Not all lights on the circuit are affected. Not all lights on dimmers switches are affected.
- Four sets of lights are affected (1 single pendant, 1 pendant light with four bulbs, 2 sets of 2 wall lights). All lights affected are on dimmer switches (with dimmable LED bulbs).
- Generally all four sets of lights flash/flicker at the same time. (ie, four hours can pass with no lights flickering, but then they will all flicker at once for the same duration).
Cheers,
James
