Hi. I'm using concrete flags/pavements, that are 900mm x 600mm x 50mm as a border between my garden and next doors. I'm laying the flags vertically, along the 900mm long side - so the flags stand in the vertical 600mm.
There is difference of height in the land between my garden and next doors, which is 11cm.
Here are the details of the cross section: The flags will be set into the ground 29.5cm on the neighbour's side. On my side, the flags will be set into the ground 40.5cm. This means that there is 11cm more in terms of depth of soil on my side. Of course, that means we don't have a balanced situation in terms of forces - there will be more force acting on the flag on my side than the neighbours side. due to the extra 11cm of soil on my side.
Now, I am intending to just fill in with the soil and tamper the soil down as it's put in The question is, if I simply fill in with soil, will the flags have a tendency to lean over in time, because of the difference in the ground levels on either side of the flags?
Also, I have a pile of sandstones that I've dug up from the garden - would it be better if I filled in with these stones and tampered them down?
Do I really need to set the flags in concrete? Thank you.
