hi could really do with some help, i noticed a leak coming down from behind the toilet pan and also a drip from inside cistern. i found out that the drip was from the pipe that feeds clean water and the seal that goes into cistern. to cut a long story short in my long frustrating day, i decided to replace the cistern. all the bits were attached inside so i got the pipe to fit from cistern to bowl, attatched the cistern to wall and thought at last all is going well. then i found that i still had the same drip from the same place. i struggled to push the gasket which is a type of polythene into the back but obviously not in enough. should i use the new rubber gasket in instead and do i put gasket into the bowl or onto the pipe. is there anything else i can do to make it watertight. help needed urgently please... chrissy
can i use silicone or plumbers mait?
