D
dextrous
Having recently designed a cheap alternative to a magnaclean (a cheap radiator with a couple of magnets stuck on it!), I have now come to the conclusion that I need to divert my mind to a new concept.
It frequently comes up on this forum that mixer taps have cold mains supply and gravity hot, for which there is currently no easy remdy other than prvs, pumps etc.
So, my concept is to develop a valvy/pump type thing which uses the flow from the cold mains to turn an impellor which "sucks" water from the hot supply so that the output flow rate/pressure from the hot and cold is equalised by this governor effect. It would require no electricity to run it, no new feeds from a flange and CWSV etc and require as much plumbing in skills as for a thermostatic mixer valve situated under the bath/sink.
What do you think?
What do you think?
