My electric shower stopped working and the light on isolation switch on the ceiling has gone out completely, nothing on the fuse board has popped,
can anyone help a dumb ass plasterer?
This is usually because one of the wires from the supply to the switch was loose in its terminal, and has burned away due to the high currents for long periods.
The fix is to fit a new switch, having cut back the heat-damaged copper to bright clean metal (the heat softens it). If you have insufficient spare length you will need an electrician to extend it with a high-pressure crimped joint.
Retighten the terminals after a week, and then again after a month, because stranded copper squashes down over time and these large terminals are prone to going loose.
Sometimes the ceiling isolator fails because it has been used to turn the shower on and off under load (when the shower knob is already turned on).
