- Joined
- 27 Jan 2008
- Messages
- 29,799
- Reaction score
- 3,694
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Pre having two boilers one for domestic water and one for central heating my one boiler did the lot. I did not have a motorised valve just a switch to turn off the pump.
With pump off boiler would only heat domestic water but if the pump ran once pipes were hot then all upstairs radiators would continue to work.
Point is of course pipes should be lagged and if lagged then once started it's only boiler and tank temperature that matters but with a low head likely needs that push to get it started.
Same with narrow boat once running thermo-siphon would work but it needed pump to get it started.
With wood burners start the water flowing before fire is lit and it can be a real pain to get fire started. Pump on narrow boat had a thermostat on the pipe right by the stove so no pump until water started to get warm. This was in fact duplicated two pumps, two thermostats and non return valves as should it not start water could boil and pumps were 12 volt to ensure no loss of supply.
It's been many years since I have used wood and coke stoves but know they can be dangerous when boilers burst so would not expect to see any stove without some fail safe. I have been there in the old days raking out the fire onto a shovel to take outside this is why we had quarry tiled floors.
