my wood burner won't gravity feed!!!!!!
Status
Not open for further replies.
22 Nov 2014
Cornwall
hello, I've installed a wood burner with a fitted back boiler into my bungalow. I have 28 mm pipe leading from the boiler going up hill for at least the first third of the run to the cylinder, which is a 28mm gravity tank It then runs steeply down into the coil out and back the same way to the boiler. any ideas why it won't gravity feed?
17 May 2008
If the flow dips down at the cylinder but the return falls constantly then it should thermosyphon.
If the return has an uphill flow after it leaves the cylinder coil then it will struggle and possibly cancel out the flow force.
8 Sep 2005
worlds end
reads as your return runs back up ? do you mean it goes up after it leaves the cylinder ?if so it has to fall back to the boiler ignore me if i have misunderstod description
26 Jun 2004
London
I wonder if it was notified to Building Control?
29 Nov 2009
Shropshire
Your cylinder probably is not designed for gravity circulation. You need to order special manufacture for gravity circulation. Alternatively, install a pump controlled by pipe thermostats which will mean you will automatically stop your fire taking away hot water from the cylinder.
26 Jun 2004
London
Sometimes these gravity systems need to get very hot before they will actually start to gravity circulate.
My friend's system in France is somewhat amusing, when the fire is started it starts gravity circulation is the opposite direction to what is required and what would be expected from the pipe layout.
But its a pumped system and when the pump is started the flow reverts to the expected direction and then continues that way even if the pump is turned off.
13 Dec 2007
If his flow runs uphill for a third of the way and then down steeply to the cylinder then it is't going to work and depending on how the pipework has been connected there is a fair chance that he will have an airlock where the pipe run changes direction too...
Status
