Hi all,
I have a Potterton boiler and a basic timer for ch and hw.
The system worked fine until a couple of days ago.
The Myson power extra has 2 led's 1 for water 2 for heating.
They are both illuminated but the heating and water isn't on.
I tried the slider on the acutator to manually open the valve but nothing happened.
I then took the acutator off and had a look. The slider moves freely with no resistance at all the valve works fine ( with pliers)
I have read that the acutator may be the problem as this kicks in and then powers the pump but none of this happens. Had the heating up full etc to force the system in to life nothing works.
Does it sound like I need a new acutator fitted? As a £40 one is a lot cheaper than a system drain and a totally 3 way new valve.
Can anyone give me a heads up?
We are ok for water as we can put the immersion on and like I say everything was working fine for the last 3 years so confident it's all properly connected etc?
Many thanks in advance for your help.
