- Joined
- 11 Mar 2006
- Messages
- 113
- Reaction score
- 1
- Country
Afternoon all.
Boiler is : Myson Midas SFI GC no. 47-494-04
Intermittent fault on HW, CH appears to work as per normal. Fault occurs approx 1 in 3 times. Here is my description of what i noted when the fault occured and some previous work done on the appliance. The initial fault was crappy ignition occasionally not sparking which a new ignition PCB cured today. Of course as the boiler now ignites, i have discovered this further fault.
When calling for HW, boiler goes "through the motions" and fires up on a low fan & flame. It does NOT go to high speed fan therefore as a result doesnt go to a high flame. Out of interest i loosened the combustion cover front panel and low and behold it went to high fan & flame. When the cover was tightened again it did NOT drop back to low. I have came to the conclusion that perhaps the fan is running slow on a low speed and not producing enough air for the airflow sensor to signal the board to go high. Does that make enough sense or just coincedence ?! Lights on PCB are 2,3,5,6. 2 goes out if fan makes high speed. 5 appears to be HW demand, 3 fan demand (?), 6 i have no idea. Theres no diagram/explanation of the diagnosis of what the lights mean.
I exchanged the airflow sensor today (brand new unused one from van stock) incase that was the prob - guess what it wasnt !
Ignition PCB also replaced today, this was the original fault as mentioned above.
There are no obstructions to the flue - air inlet is clear (its rear exit i can see straight out it) and a torch up the inner flue from outside shows no probs either.
CW, HW and CH sensors were replaced by me approx 6 - 8 weeks ago due to CH never satisfying. The tenant mentioned that the HW seemed to "act up" early last week and the boiler eventually packed in (with ignition prob) on saturday. I assume there was 2 or more faults on this appliance.
Any asistance greatly appreciated. Perhaps it is a "slow" fan on low, or is the main PCB not understanding the signal from the airflow sensor ?
Cheers for reading, soz re: long post !
