Hi, I just dismantled an old fitted wardrobe in preparation for some new ones to be fitted in a few weeks time.
The ceiling above the space where the old wardrobes were is bare plasterboard.
View media item 97519
The new wardrobes are going to be slightly narrower that the old ones hence i will have a small area of about 350X650mm of the bare plasterboard showing once the new wardrobes get fitted.
The question is what is the name of the textured product on the ceiling so that I can match up the small area that will be exposed?
I think its artex but wanted to confirm before i go and buy some.
Also regarding application, can it go straight on to the plasterboard, or is there any type of surface prep that will be required before hand?
When it comes to painting will i need to apply a diluted paint base coat in a similar way that you would to a freshly plastered wall before applying the top coats?
Rob
Rob
