neataheat16-22
26 Sep 2007
Essex
Can anyone give me the wiring diagram for the pump overrun please on a neataheat 16-22
In what way?, the pump is wired in to E, N and 6 on the terminal block and controlled by the boiler stat.
thepump overrun does not seem to work thought I would trace the wiring to see if there was a fault :LOL:
Thanks ollski c
Ihave checked the block wired to E,N with a bridge to 5 should I change it to 6
Did it used to work?, have you altered any wiring?, if not suspect the boiler stat.
