Need a needle valve - 'Y' with two taps???
23 Feb 2005
West Midlands
Hello!
Thanks for your input on my last thread - i've now got a load of options and some names of things so i can ask properly.
I'm looking for a needle valve - it would be good if i could get one that has one input and two outputs - with the valve controlling the two. So as one increases, the other decreases.
The problem i have with finding these things is i don't know what they are called.
I am looking for them in 6mm.
Thanks for any help you can give about either sourcing or naming such a tap - is there a name for it?
Thanks,
Mr. Tickle.
Ok, wossit for? Are you seeking to share pressure or flow?
Mains water? If not, then what pressure?
OK, the thread title is a little confusing, i need one tap...
It's for liquid flow, at atmospheric pressure, it's open so i think that's atmospheric??
SO yea, one tap that switches the flow from one to the other...
Cheers Chris!
Cheers Chris!
A three way vent cock would do the trick, only problem is the smallest I know is 20mm (3/4") and cost £165 each.
Will try and think of something else :roll:
Mr. Tickle said:
It would be easier to have a two valves setup together, i guess.
depends on its use, a 3way vent cock always has two ports open either with a flow or without
Thems all single valves TicklyT
Now I got to pluck a partridge so back later  8)
Yea, just like those RS ones, but with two outputs. One tap controlling both. So 'A' is on 100% then 'B' is on 0% - as you turn the tap, it moves to 80/20, 50/50, 30/70 etc etc.
My thought is to use two needle valves set with the knobs facing each other. Drill the knobs and fit a couple of pins to lock them together, then as you open one valve, the other shuts.
Or use a shaft coupling in place of the knobs
Or push the knobs into either end of a short piece of plastic or rubber tube.
