Need to lay a laminate style wood floor.
Normally I would start on longest wall, and but am laying in very small hall which has two doors, 1 to a tiled floor WC and one to the lounge. The doors are virtually at the front door.
As I need to put the floor partially beneath the WC door frame, should I start there and do the hall before going into the lounge. Can't see how I would get the planks in if I work towards hall.
The hall is shorter than a plank so several small bits are required.
Lounge is pretty simple with just a blocked up chimney breast, and doors to kitchen and conservatory. Kitchen having different laminate flooring, with conservatory having same as lounge.
