Then put an electrician in charge.im not looking to wire it up myself as i agree i dont have the experience but i dont want to anyway as at the end of the day its water and electrics
and not putting family at risk
Did he sign an EIC to say that he designed and installed it all?ive done first fix myself in new room (a spark told me what to do)
Did he certify to LABC that he did all the work?
Then find him before you start doing anything and have him make all the design decisions, and have him instruct you and supervise you, or you won't get an EIC or notification to LABC. Unless the guy is bent.i will employ a spark to do final fix but want to have all ready for him to be finished there and then
That isn't how it works.when i have it all ready and built will get 1 of the sparks on job to come to my house and wire up as its quite a lot of cable to pull in and dont want to be paying alot in man hours so he can inspect it for certificate
Are all the electricians where you work registered in their own right with Competent Person schemes?
What if there's a problem, not with the cables you've installed but where you installed them?as for cable already done for the lights/sockets its only 7 metres long for sockets and lights so if he needed to he can use wires i put in for draw wires
The sort the electrician in charge tells you is needed.i just want to know for now what type breaker is needed for the tub
You're planning to "design" and install all this, and you don't even know the answer to that?can i put rcd on sockets?
I thought you didn't want to put your family at risk?
Not plugs and sockets.some poeple have mirror tvs in bathroom shaver sockets ect so there must be something that make it work?
Too little and too late.this why i asking these questions so buy the right stuff
And weighs over 2kg/m. How many m did you lug to your car, Dave?Looks more like 2.5mm 4 core.
25mm 4 core is about 1¼" thick
More than you need?i have a 25mm armoured cable from the house to the room im a joiner by trade and 1 of the sparks gave it me as told him wot i was doing
its more than i need i know but it was free and told suitable
If it really is only 2.5mm², and he gave it to you saying it was suitable for a 63A circuit then when you are looking for an electrician to take charge of this project, don't use him, unless you want to put your family at risk...
