Hot Tub what size SWA
20 Mar 2011
Surrey
Hello,
I have a hot tub on the way and am in the process of getting decking installed,I want to get the swa in place while there is no decking but i would like some advice on what size swa i need.
The hot tub pulls 13 amps and calls for a 15 amp circuit breaker
The hot tub is 10 meters away from the consumer unit.
would 2.5mm swa be ok ?
I will be getting a electirican in for the final connection and cable make off,but would like to know what cable size before the decking is down.
your help would be much appreciated.
thankyou
Thankyou for coming back so quickly
sorry one more question.
what type of breaker would i need to buy?
what do you mean, what type of breaker?
it will need to be rcd protected, if thats what you mean.
its only a starter hot tub, round with 18 jets.
sorry i meant what type of breaker, i have a fairly old wylex cu with plug in breakers.
what breaker woudl i need to fit in here, is it a type c?
and will it plug in or would you need a seperate rcd in enclosure?
thankyou
This work is notifiable, and your plan assumes that that works in a way which it does not. You may not install a new circuit and just get an electrician in to connect it.
Never mind how many jets it has - how big is it?
i.e. how many l of water in it?
Bearing in mind that the specific heat of water is 4.19J/gK, a physical fact which no amount of marketing bumpf can get around, have you thought about how long it will take a 3kW (at best) heater to raise that much water to the required temperature?
Will the Zs of the circuit allow the use of a Type C?
What zone would any socket be in?
If you have plug in breakers then you need to get a periodic inspection report done on your wiring before you o anything.
