Hello guys,my oldish Excell 80sp suffered a main heat exchanger failure last week with water going through the main burner and over everything below.A new HE was duly fitted and the boiler worked a treat afterwards.However yesterday it went off with the pilot out and the pressure down.I thought OK it's just the water volume settling down after bleeding etc.I upped the pressure to within the normal range and relit the pilot but the main burner would not come on.It goes through the motions with all the familiar clicks as if it's going to light up but doesn't.
I've cleaned the venturi, replaced the air pressure switch,the high limit stat and even put a new PCB in as I thought the original might be water damaged from the HE leak all to no avail.
The pump runs, the fan runs at both speeds,the water pressure is holding up and the pilot lights. Where do I go from here?
Don't fancy too many nights without heating!
Thanks in advance for any ideas.
