Need help with Worcester 240 Combi RSF
23 Dec 2004
OK this is my problem. Where the two flow and return 22mm pipes enter the boiler, they are connected to a compression fitting which has an on/off screw to them. After turning one of these screws to stop the flow, it now leaks. I need to know either the item number or what these are called so I can order them.
Oh its a Worcester 240 Combi RSF.
Any help most welcome.
Mark.
22m ball-a-fix. Or isolation valves. Or for quick fix , drain down , remove , solder where its leaking from , replace and refill.
Find the data plate on the boiler inside the casing. There should be a number that goes something like GC 43-517-25 That is the old Gas Council product identifier. Then go to plumbers merchants with the boiler type and your GC number and they will order the part for you.
Alfredo
