Need new mid position valve, any good suggestions!
30 Dec 2008
Hampshire
Hi
I have found out that my 3 port mid position valve is nt working and have to buy a new one. It is a Landis and Gry MAV 322 I think it has 22mm connections on it.
It seems you can no longer get these but may be able to get a similar one from siemens. But these do not have the removalbe box on top so if it goes again i will have to replace the whole thing again. (Drain the system and everything...FUN!!)
Does any one have a good suggestion for a replacement for this
Cooper
As I've already stated in your other post, Honeywell or Danfoss.
The seimens heads do come off, they just click on and off, well the ones I've fitted have done anyway.
I only fit the honeywells, all the others are shyte.
sorry dave, you siad the heads click on and off if that is the case i will not have to drain the system to replace the whole valve assembly! Hoping!
The new Siemens heads won't be compatable with the old Landis & Gyr :cry:
Hardly anything is.
Bummer!
Not looking forward to that job then!! lol
Thanks alot for all your help, I have used many forums before in the past but this one amazes me how quickly people reply!
Added to my favourites now for when I redo the bathroom :D
