- Joined
- 16 Nov 2023
- Messages
- 2
- Reaction score
- 0
- Country
Hi all,
So today I was changing a damaged socket for a new one. Simple job, inserted the wires where they should be, old style red, black and earth.
When switching the circuit back on on the consumer unit the breaker tripped straight away.
So, I went back to the socket, loosened it back off to check for any wire coming loose (which they hadn't).
With the socket loosened off I tried switching the power back on and this time it stayed on.
When fastening the socket back into place there was a nice pop and little bit of smoke (I'm guessing a short?).
So, my questions.
There is probably more copper showing than needed from the live and neutral, could this be the earth wire hitting the copper once its getting pushed back on and compressed?
If so should I trim it?
After this socket popped will it be okay to still use this one or will I need another new one?
The earth wire inside the socket is bare wire, should I cover it? If so, what is best to use?
Thank you in advance as I know this is a long post for a first post
So, my questions.
