Hi guys
My father in law has had underfloor heating fitted to his new build. In the upstairs the existing chipboard floor has been battened with 20mm battens. Aluminium trays are placed between the battens and pipe (16mm) laid into grooves in the trays. So far so good, but having come to fit the next layer of chipboard flooring over the top of this arrangement, it turns out that the clips that hold the pipes down are 22mm high!
Thus, problem is the new floorboard rests on the occasional clips rather than on the battens as intended. not ideal
So far the routes I've considered are:
Get some strip wood, or thin sheet material like hardboard, rip it into strips on the table saw and pack every batten on top (stapler would do) to bring the level up a few mm to give clearance
run round with a few tubes of stickslikesh*t and glue the pipes down (pump it into the seam between pipe and floor, near a clip) then when it's gone off, pull the clips out and lay the flooring
Has anyone any other ideas? I'm reluctant to take an angle grinder with flat wheel to the top of the clips in case the pipe gets damaged..
