Need tiny ball bearing for ratcheting screw driver
Status
Not open for further replies.
23 Mar 2007
Cheshire
I've lost the small ball bearing which is part of the mechanism that retains the bit inserted into my ratcheting screw driver. Having searched around the Internet I've concluded that this is a common mode of failure.
Will they likely all be the same size? I can get ball bearings on eBay but it's difficult to say what size it should be... about 3 or 4 mm?
Are you serious? Just buy a new screwdriver.
Better still, join us in the 21 century and buy a cordless.
That seems pretty wasteful considering that the same thing might happen again with the next one anyway judging by comments I find around the internet. All I need is one ball bearing. And this screw driver is part of a set that I'd like to keep whole.
I don't know what value you place on your time, but the faff factor alone would say chuck it.
...and is likely to happen to the one you fix too.
Buy a cordless and sling the entire set or retire it someplace. Just salvage the screwdriver bits from the ratchet fella. You will never use a hand held again.
I already have one but it's at home and I don't want to have two. Besides, I feel validated when an inanimate object tries and fails to defeat me. I've ordered 50 4 mm steel balls for just 99p including delivery!
what are you going to do with the other 49 ball bearings?
He has 49 more chances of repairing it without have to search around again, the problem will be that he will put them somewhere safe and never find them again....lol
Okay, so it turned out that 3 mm was the correct size. It took less than a minute to fix though; if it takes you two hours then seek help from an adult who should already be involved to make sure you don't swallow the parts...
As for the other ball bearings, they'll go into my miscellaneous parts tool box, probably never to be found again, as pompeyal suggests.
Status
