Need to increase room size of 0.2 m2, per HMO regulations
20 Mar 2007
London
I have a house that I have been renting out to sharer's. One of the rooms is 6.32 m2. Too small to be rented out by 0.2m2.
I was hoping that replacing the plasterboard with a thinner plasterboard might do the trick, but honestly, there is still not much space. It was already optimally used. Can anyone recommend an ultra thin plasterboard?
Changing the plasterboard seems a pretty drastic solution that might not buy you those extra 2000cm2!
For a start, I would get a definitive set of dimension, are the walls truly parallel and are you measuring above the skirting boards etc.
If you can post some pictures / plans, we may be able to come up with some ideas.
For instance, can the door be moved further out of the door frame?
I also hope that the occupant of this room is going to get a decent discount! :)
