I have a old barn on my property that was half buried on one end, and in the air on the other. I've been digging it out of the muck, but have lots of rotted wood. The barn is not worth investing too much money into.
The side in the air is sagging, and I'm trying to re-level it. I jacked the corner up and got a cinder under part of it. However I'm not sure cinder blocks are a permanent solution, and I'm wondering what you guys recommend.
The picture attached is of the corner that used to be in the air. The middle of this side is still sagging so I'll need to work my way down and put supports in, but I want to make sure I'm using the right material. With a railroad tie or pressure treated 4x4 be a better solution?
This barn will be for animals and isn't worth replacing all the wood or otherwise investing heavily, however it is a 16x20 barn with an A frame loft. It was 2 ft deep in a hill on the far side.
This part needs to be dug out and lifted, it's to the center of the first pick.
