hi hope someone can help. firstly the machine would not even start could hear the motor kicking in but no water would spray. pulled machine out not sure what iam looking at though. cant see any pipes that have come off or loose. replaced ingrated machine into iits position switched on and reset the system as instructed in booklet and the machine kicked in and i could hear water being sprayed inside. within 30sec water was leaking from i think underneath quite rapidly. what sould i be looking for when i pull it back out to find the leak??? thank you
