Neff double oven installation
2 Nov 2007
Do I need ring tags crimped to my cooker cable, to attach to my Neff series II double oven?. If not then how does the neutral and live attach to the oven itself?
Under the screw clamps? On most ovens theres a screw, with a square washer under it. The wire goes under the square washer, wrapped around the shaft of the screw, such that the screw draws the wire in as you tighten.
