Can someone advise if the best solution for a friends loft conversion. Currently they have a single positive head pump to the basin in the loft. This does not work because there is no flow rate to get the pump started as the f&e tank is below the tap.
Is the only solution a negative head pump and will this definately work in this situation? (unsure how negative head pumps activate)
thanks
thanks
