negative head shower pump location
4 May 2012
Sussex
just a quick question just in the process of a loft conversion and just wondered if a negative head sp can be mounted by the cold water tank and then drop the pipes for the hot water down to the cylinder in the airing cupboard below?
cheers
no the pump needs to be under the level cold water tank, every pump is different so you need to follow the installation instructions.
