Neighbors in council house coverted loft
Hardly a surprise that! Shoddy new builds are the news quite a lot these days
Still surprising to me that houses should be built without party walls where required . Houses could be built shoddily in some respects and still comply with building regulations because they don't really cover 'workmanship'.
Some new houses are built with all sorts of major defects, even down to mortar that does not set!
I get what @Leofric is saying though, there's a difference between doing something badly and not up to code, and not even doing it at all
I'm sure that weak mortar is not "up to code".
Yes that was exactly my point... You might get terrible mortar but it would be very unlikely they'd forget to put mortar in at all.
I think you've misread my post.
I've seen photos of new builds with zero loft insulation so I'm not surprised!
Also some new builds by design don't really have a party wall in the loft, more like a party-plasterboard
Party walls have to comply with sound and fire resisting regulations whether they are constructed of blockwork or plasterboard etc. There are approved constructions for party walls in plasterboard and studding and insulation.
What? Lime mortar is unacceptable?
Are they using lime mortar on many new houses nowadays :?::!:
ps I doubt if securespark was referring to lime mortar so how about the situation with cement/sand mortar :?:
You don't get told "no" when you apply. (How do they even know what's in your loft?)
You tell the council that you are doing it and they just check the work.
We were told we couldn't convert it in its current form by our BCO. He said the joists weren't strong enough and the head height was too low
That's still not how building regulations work.
What happens is, you prepare a design, submit an application, the design gets checked and either approved or changes requested before the design is approved.
BCO's don't just say "no", neither can they, and they can't even comment unless an application is made. Perhaps you got an opinion.
I was building a garage at the time and the BCO was out checking it at completion and I asked at the time if we could convert the loft and he looked said not without replacing the timbers and also the height would only be 1.7m in the centre
That's not a "no" then. That's a statement of fact.
Almost every loft conversion requires new timbers for a floor. How that is done, and how height is dealt with is all down to the designer. There is no height restriction for loft rooms either.
