- Joined
- 27 Jan 2017
- Messages
- 2
- Reaction score
- 0
- Country
I’m looking to self install a Nest Learning Thermostat on my Worcester Bosch 280 boiler.
The wiring looks straight forward, but I just wanted to sense check before I go ahead.
The boiler doesn’t have a stat currently, so on the stat section has an unused N connection.
1 & 2 are jumpered (2 shows 240v, 1 is 0v), a 3 is unsued and unmarked, and 4 is unused and marked Frost Stat.
So I assume I can run a 4 core to the Nest Heatlink, and wire up as follows :-
N from boiler to N on heatlink
2 (240v Live) from boiler to L on heatlink, and then jumper L on the heatlink to common / 2(do I need to run a 3A inline fuse or not? On the jumper cable)
1 from boiler to 3 (relay open) on the Heatlink
Earth (needed or not? As Nest stat will be wireless)
Is that pretty much it, bar testing, tidying, and testing again?
