- Joined
- 6 Nov 2022
- Messages
- 11
- Reaction score
- 2
- Country
Hi Everyone
I am hopeful someone smart on here can help me out....
I had a Nest 3rd gen learning thermostat connected to my Ideal Heat 12 System Boiler. It was flakey the entire time we had it. Google replaced the heat link once and the thermostat once in the first 12 months.
This year it seems worse. The heating just came on for the first time and the burner stayed on indefinitely. house got very hot and I had to turn the boiler off at the mains. At this point we'd had enough so at the recommendation of a friend, went out and bought "Hive Active V3 Wireless Heating & Hot Water Smart Thermostat".
I tried to install it myself as I have thermostats in previous houses, just not Hive's.
The problem is the boiler turns on but seems to not respond to the Hive, most of the time the burner just stays on but will periodically turn off for no apparent reason.
My Ideal Logic Heat 12 only has 2 cables, Heating on (NO) and Hot Water on (NO) but neither of the diagrams on the Hive installation manual seem to match my situation. I don't appear to have Heating off (NC) or Hot Water off(NC)
My Nest, which did work for a while was wired in as follows:
And although it was flakey it did work for a year pretty well.
The Hive is currently wired in as follows:
But the burner comes on as soon as the boiler turns on, and it stays on almost all the time.
I have no idea what I need to do to sort it out. I don't even know if I need to call a plumber or an electrician.
Does anyone have any ideas or knowledge that might help me here?
Thanks in advance
Thanks in advance
